CHI Original Power Cord Replacement
  1. CHI Original Power Cord Replacement, Hinge Spring: step 1, image 1 of 2 CHI Original Power Cord Replacement, Hinge Spring: step 1, image 2 of 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Power Cord Replacement: step 2, image 1 of 1
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Power Cord Replacement: step 3, image 1 of 1
    • Remove the hinge pin.
  4. CHI Original Power Cord Replacement: step 4, image 1 of 1
    • Separate the two halves of the CHI Original.
  5. CHI Original Power Cord Replacement: step 5, image 1 of 2 CHI Original Power Cord Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Power Cord Replacement, Power Cord: step 6, image 1 of 2 CHI Original Power Cord Replacement, Power Cord: step 6, image 2 of 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Power Cord Replacement: step 7, image 1 of 1
    • Gently pull upwards on the connection point and disconnect the power cord.
Eric Knigga
215 Reputation
2 Guides authored
IUPUI, Team S1-G2, Freund Fall 2017 Member of IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Members
3 Guides authored
5 Comments
Do you know where to get a replacement power cord?
Taylor Bradford - Reply
How/where do you purchase the replacement cord?
fixitman - Reply
Where do you order an actual cord from??
Kelly Hickman - Reply
Where we can get Power Cord?
Nazim - Reply
Bonjour Nazim, j'ai trouvé le bon câble pour réparer le modèle GF1001EUN Farouk Systems USA sur le site web de pgservice :
Hi Nazim, I found the right cable to repair the GF1001EUN Farouk Systems USA model on the pgservice website :
https://pgservice.cc/fr/products/gammapi...
Sonny -
Past 24 Hours: 9
Past 7 Days: 21
Past 30 Days: 109
All Time: 6,370
