CPU Fan Replacement
  1. CPU Fan Replacement, Back Panel: step 1, image 1 of 2 CPU Fan Replacement, Back Panel: step 1, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. CPU Fan Replacement: step 2, image 1 of 2 CPU Fan Replacement: step 2, image 2 of 2
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  3. CPU Fan Replacement, CPU Fan: step 3, image 1 of 2 CPU Fan Replacement, CPU Fan: step 3, image 2 of 2
    • Remove the header by pulling on it with two fingers.
  4. CPU Fan Replacement: step 4, image 1 of 1
    • Remove the six 2.5mm screws using a Phillips #1 screwdriver.
  5. CPU Fan Replacement: step 5, image 1 of 1
    • Remove the fan by moving it to the side and lifting it out of the computer.
Armani Tayeh
447 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,079
