CR-10 V2 Print Head Teardown
  1. CR-10 V2  Print Head Teardown, Teardown: step 1, image 1 of 3 CR-10 V2  Print Head Teardown, Teardown: step 1, image 2 of 3 CR-10 V2  Print Head Teardown, Teardown: step 1, image 3 of 3
    • Make sure all power cables to your 3D Printer are unplugged including wall plugs (A/C) and/or USB cables.
    • Using M2 hex remove the 3 button head screws holding the print head to the X carriage plate.
    • Using M2 hex, remove the 4 screws holding the hot end fan in place (2 screws attach to the front half and the other to the rear)
    • Using M2 hex, remove 3 button head screws that secure front and rear sections together. Do not try to pull apart yet!
  2. CR-10 V2  Print Head Teardown, Teardown: step 2, image 1 of 3 CR-10 V2  Print Head Teardown, Teardown: step 2, image 2 of 3 CR-10 V2  Print Head Teardown, Teardown: step 2, image 3 of 3
    • Using M2 hex, remove the 2 button head screws securing the part cooler fan. 1 attaches to the front and the other to 2 rear.
    • Pull the front half off to expose the rear section and hot end.
    • Now, treat it like an E3D V6 hot end. However, the nozzle is not V6 style.
    • The stock nozzle is MK8 just like standard CR-10/ CR-10S
3 other people completed this guide.
Tiny Machines 3D
2,970 Reputation
14 Guides authored
Tiny Machines 3D Member of Tiny Machines 3D
Community
5 Members
40 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 23
All Time: 8,061
