Cabinet Door Butt Hinge Replacement
  1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: step 1, image 1 of 1
    • Determine where the cabinet needs repair: on the top or bottom hinge.
  2. Cabinet Door Butt Hinge Replacement: step 2, image 1 of 1
    • Measure the hinge to make sure you have the correct size of your butt hinge.
    • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
  3. Cabinet Door Butt Hinge Replacement: step 3, image 1 of 1
    • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
    • Keep the screws nearby; you will need them later.
  4. Cabinet Door Butt Hinge Replacement: step 4, image 1 of 1
    • Align the cabinet door to stand straight with any surrounding cabinets.
  5. Cabinet Door Butt Hinge Replacement: step 5, image 1 of 1
    • Place the new hinge where the previous one was. Align the holes together.
  6. Cabinet Door Butt Hinge Replacement: step 6, image 1 of 1
    • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
If the door closes parallel to any surrounding cabinets, your fix is complete!
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 47
All Time: 301
