Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: step 1, image 1 of 1
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: step 2, image 1 of 3 Calculator is Stuck While Graphing: step 2, image 2 of 3 Calculator is Stuck While Graphing: step 2, image 3 of 3
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: step 3, image 1 of 1
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: step 4, image 1 of 2 Calculator is Stuck While Graphing: step 4, image 2 of 2
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
It is always a good idea to make sure your graph will display a good window.
John Baek
31 Reputation
4 Guides authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,138
