CanoScan LiDE 35 Scanner Bar Replacement
  1. CanoScan LiDE 35 Scanner Bar Replacement, Scanner Glass: step 1, image 1 of 3 CanoScan LiDE 35 Scanner Bar Replacement, Scanner Glass: step 1, image 2 of 3 CanoScan LiDE 35 Scanner Bar Replacement, Scanner Glass: step 1, image 3 of 3
    • Slide plastic opening tool under the plastic.
    • Gently pry the plastic framing off the glass.
    • Repeat on the other side.
  2. CanoScan LiDE 35 Scanner Bar Replacement: step 2, image 1 of 2 CanoScan LiDE 35 Scanner Bar Replacement: step 2, image 2 of 2
    • Remove the front plastic frame.
  3. CanoScan LiDE 35 Scanner Bar Replacement: step 3, image 1 of 3 CanoScan LiDE 35 Scanner Bar Replacement: step 3, image 2 of 3 CanoScan LiDE 35 Scanner Bar Replacement: step 3, image 3 of 3
    • Wedge the plastic opening tool under the glass.
    • Pull up against glass.
    • Slide the glass forward.
    • Remove the glass.
  4. CanoScan LiDE 35 Scanner Bar Replacement, Scanner Bar: step 4, image 1 of 1
    • Remove the scanner bar.
    • Replace the scanner bar back onto metal center bar.
2 other people completed this guide.
Nick
152 Reputation
1 Guide authored
1 Guide Comment
Hello Nick, thank you for the guide.
My CanoScan LiDE 220 has started to introduce a line down the middle of the page when I scan with VueScan. Not sure if this guide applies.
Mark Leung - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 22
All Time: 2,507
