CanoScan LiDE 35 Scanner Glass Replacement
  1. CanoScan LiDE 35 Scanner Glass Replacement, Scanner Glass: step 1, image 1 of 3 CanoScan LiDE 35 Scanner Glass Replacement, Scanner Glass: step 1, image 2 of 3 CanoScan LiDE 35 Scanner Glass Replacement, Scanner Glass: step 1, image 3 of 3
    • Slide plastic opening tool under the plastic.
    • Gently pry the plastic framing off the glass.
    • Repeat on the other side.
  2. CanoScan LiDE 35 Scanner Glass Replacement: step 2, image 1 of 2 CanoScan LiDE 35 Scanner Glass Replacement: step 2, image 2 of 2
    • Remove the front plastic frame.
  3. CanoScan LiDE 35 Scanner Glass Replacement: step 3, image 1 of 3 CanoScan LiDE 35 Scanner Glass Replacement: step 3, image 2 of 3 CanoScan LiDE 35 Scanner Glass Replacement: step 3, image 3 of 3
    • Wedge the plastic opening tool under the glass.
    • Pull up against glass.
    • Slide the glass forward.
    • Remove the glass.
3 other people completed this guide.
Shannon
364 Reputation
2 Guides authored
Clemson, Team 1-89, Diaz Fall 2013 Member of Clemson, Team 1-89, Diaz Fall 2013
CLEM-DIAZ-F13S1G89
1 Member
5 Guides authored
3 Guide Comments
Can you tell me the glass dimensions (size) WxHxD in millimeters.
Spavl - Reply
The dimensions of the glass: 247 mm x 339 mm x 3 mm (w x h x d)
Cray -
Can we replace any ordinary glass ? R there are any specifications for glass quality/type ?
Shiva Ganesh - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 2,364
