CanoScan LiDE 35 Square Port Removal
  1. CanoScan LiDE 35 Square Port Removal, Scanner Glass: step 1, image 1 of 3 CanoScan LiDE 35 Square Port Removal, Scanner Glass: step 1, image 2 of 3 CanoScan LiDE 35 Square Port Removal, Scanner Glass: step 1, image 3 of 3
    • Slide plastic opening tool under the plastic.
    • Gently pry the plastic framing off the glass.
    • Repeat on the other side.
  2. CanoScan LiDE 35 Square Port Removal: step 2, image 1 of 2 CanoScan LiDE 35 Square Port Removal: step 2, image 2 of 2
    • Remove the front plastic frame.
  3. CanoScan LiDE 35 Square Port Removal: step 3, image 1 of 3 CanoScan LiDE 35 Square Port Removal: step 3, image 2 of 3 CanoScan LiDE 35 Square Port Removal: step 3, image 3 of 3
    • Wedge the plastic opening tool under the glass.
    • Pull up against glass.
    • Slide the glass forward.
    • Remove the glass.
  4. CanoScan LiDE 35 Square Port Removal, Square Port: step 4, image 1 of 3 CanoScan LiDE 35 Square Port Removal, Square Port: step 4, image 2 of 3 CanoScan LiDE 35 Square Port Removal, Square Port: step 4, image 3 of 3
    • Locate three screws on the grey shell.
    • Unscrew the three screws.
    • Separate the grey shell from case.
  5. CanoScan LiDE 35 Square Port Removal: step 5, image 1 of 3 CanoScan LiDE 35 Square Port Removal: step 5, image 2 of 3 CanoScan LiDE 35 Square Port Removal: step 5, image 3 of 3
    • Separate the grey shell from square port.
  6. CanoScan LiDE 35 Square Port Removal: step 6, image 1 of 3 CanoScan LiDE 35 Square Port Removal: step 6, image 2 of 3 CanoScan LiDE 35 Square Port Removal: step 6, image 3 of 3
    • Locate the ribbon cable on casing.
    • Remove the ribbon cable on casing.
  7. CanoScan LiDE 35 Square Port Removal: step 7, image 1 of 1
    • Once the ribbon cable is removed, locate the square port.
    • Remove the square port.
Shannon
364 Reputation
2 Guides authored
Clemson, Team 1-89, Diaz Fall 2013 Member of Clemson, Team 1-89, Diaz Fall 2013
CLEM-DIAZ-F13S1G89
1 Member
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 910
