Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement
Paul
Paul and 3 other contributors
Last updated on January 3, 2025
15 - 25 minutes
Moderate
Introduction
Go to step 1
In this guide, you will learn how to replace the main board in the EF-S 18-135mm lens. The main board is crucial to the correct operation of the lens, passing focus commands from the camera to the lens.
Tools
Show more…
  1. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: step 1, image 1 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: step 1, image 2 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: step 1, image 3 of 3
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 2, image 1 of 2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 2, image 2 of 2
    • Remove the four 5.5mm JIS #000 screws for the lens mount ring (silver ring).
    • Remove the two 4mm JIS #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 3, image 1 of 2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 3, image 2 of 2
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 4, image 1 of 2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 4, image 2 of 2
    • This step involves handling sensitive electronics. Avoid static discharge.
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 5, image 1 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 5, image 2 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 5, image 3 of 3
    • Remove the two 4mm JIS #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
Paul
873 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 2,633
