Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: step 1, image 1 of 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: step 1, image 2 of 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: step 1, image 3 of 3
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: step 2, image 1 of 2 Canon ELPH Z3 Camera Battery  Replacement: step 2, image 2 of 2
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
Nathan Barros
1 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Catania Fall 2016 Member of UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 766
