Canon ELPH Z3 Camera Film Chamber Replacement
  1. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: step 1, image 1 of 3 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: step 1, image 2 of 3 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: step 1, image 3 of 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Film Chamber Replacement: step 2, image 1 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 2, image 2 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 2, image 3 of 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Film Chamber Replacement: step 3, image 1 of 2 Canon ELPH Z3 Camera Film Chamber Replacement: step 3, image 2 of 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Film Chamber Replacement: step 4, image 1 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 4, image 2 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 4, image 3 of 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Film Chamber Replacement, Film: step 5, image 1 of 2 Canon ELPH Z3 Camera Film Chamber Replacement, Film: step 5, image 2 of 2
    • Separate the front and back coverings of the camera completely.
    • Remove both coverings from the body of the camera.
    • Flip the camera upside down and focus on the bottom right portion.
  6. Canon ELPH Z3 Camera Film Chamber Replacement: step 6, image 1 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 6, image 2 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 6, image 3 of 3
    • Unscrew the 4.1mm screw using a PH000 screwdriver.
    • Swivel the now loose metal portion to the right.
    • This action will open the film chamber and thus exposing the film.
  7. Canon ELPH Z3 Camera Film Chamber Replacement: step 7, image 1 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 7, image 2 of 3 Canon ELPH Z3 Camera Film Chamber Replacement: step 7, image 3 of 3
    • Press gently on the film using your finger to slightly eject the film.
    • Pull the film from the chamber.
Nathan Barros
1 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Catania Fall 2016 Member of UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 922
