Canon ELPH Z3 Camera Image Sensor Replacement
  1. Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: step 1, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: step 1, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: step 1, image 3 of 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Image Sensor Replacement: step 2, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 2, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 2, image 3 of 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Image Sensor Replacement: step 3, image 1 of 2 Canon ELPH Z3 Camera Image Sensor Replacement: step 3, image 2 of 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Image Sensor Replacement: step 4, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 4, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 4, image 3 of 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: step 5, image 1 of 2 Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: step 5, image 2 of 2
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Image Sensor Replacement: step 6, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 6, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 6, image 3 of 3
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Image Sensor Replacement: step 7, image 1 of 2 Canon ELPH Z3 Camera Image Sensor Replacement: step 7, image 2 of 2
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
  8. Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: step 8, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: step 8, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: step 8, image 3 of 3
    • Pull away back screen base to reveal the image sensor.
    • Remove image sensor using a set of pliers.
Katy Skillings
1 Reputation
2 Guides authored
UMass Dartmouth, Team 1-7, Catania Fall 2016 Member of UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 282
