Canon EOS 30 Remote Control Socket Replacement
  1. Canon EOS 30 Remote Control Socket Replacement, Front Panel: step 1, image 1 of 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Remote Control Socket Replacement: step 2, image 1 of 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Remote Control Socket Replacement: step 3, image 1 of 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Remote Control Socket Replacement: step 4, image 1 of 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Remote Control Socket Replacement, Bottom Panel: step 5, image 1 of 1
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Canon EOS 30 Remote Control Socket Replacement: step 6, image 1 of 1
    • Remove the bottom panel.
  7. Canon EOS 30 Remote Control Socket Replacement, Side Panel With Remote Control Socket: step 7, image 1 of 1
    • Remove two 6.5 mm black screws from the panel.
  8. Canon EOS 30 Remote Control Socket Replacement: step 8, image 1 of 1
    • Remove the plastic remote control socket cap by pulling it straight out.
  9. Canon EOS 30 Remote Control Socket Replacement: step 9, image 1 of 2 Canon EOS 30 Remote Control Socket Replacement: step 9, image 2 of 2
    • Slide the panel toward the bottom of the camera to remove.
  10. Canon EOS 30 Remote Control Socket Replacement: step 10, image 1 of 1
    • Remove the single 4.8 silver screw from the control socket.
  11. Canon EOS 30 Remote Control Socket Replacement: step 11, image 1 of 2 Canon EOS 30 Remote Control Socket Replacement: step 11, image 2 of 2
    • The control socket is now secure by three wires.
    • Desolder connections to replace the remote control socket.
  12. Canon EOS 30 Remote Control Socket Replacement, Remote Control Socket: step 12, image 1 of 1
    • Remove one 4.8 mm silver screw securing Remote Control Socket to camera.
  13. Canon EOS 30 Remote Control Socket Replacement: step 13, image 1 of 2 Canon EOS 30 Remote Control Socket Replacement: step 13, image 2 of 2
    • Remote Control Socket is now secured by 3 wires.
    • Desolder connections to replace Remote Control Socket.
2 other people completed this guide.
Antonia
124 Reputation
2 Guides authored
Cal Poly, Team 8-8, Regan Spring 2011 Member of Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 3,094
