Canon EOS 300 Top Panel Replacement
  1. Canon EOS 300 Top Panel Replacement, Batteries: step 1, image 1 of 3 Canon EOS 300 Top Panel Replacement, Batteries: step 1, image 2 of 3 Canon EOS 300 Top Panel Replacement, Batteries: step 1, image 3 of 3
    • Open up the battery door.
  2. Canon EOS 300 Top Panel Replacement: step 2, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 2, image 2 of 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Top Panel Replacement, Side Panel with Lever: step 3, image 1 of 2 Canon EOS 300 Top Panel Replacement, Side Panel with Lever: step 3, image 2 of 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Top Panel Replacement: step 4, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 4, image 2 of 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Top Panel Replacement: step 5, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 5, image 2 of 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Top Panel Replacement, Front Panel: step 6, image 1 of 2 Canon EOS 300 Top Panel Replacement, Front Panel: step 6, image 2 of 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Top Panel Replacement: step 7, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 7, image 2 of 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Top Panel Replacement: step 8, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 8, image 2 of 2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Top Panel Replacement, Bottom Panel: step 9, image 1 of 2 Canon EOS 300 Top Panel Replacement, Bottom Panel: step 9, image 2 of 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Top Panel Replacement: step 10, image 1 of 3 Canon EOS 300 Top Panel Replacement: step 10, image 2 of 3 Canon EOS 300 Top Panel Replacement: step 10, image 3 of 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Top Panel Replacement, Side Panel with Grip: step 11, image 1 of 3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: step 11, image 2 of 3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: step 11, image 3 of 3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Top Panel Replacement: step 12, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 12, image 2 of 2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Top Panel Replacement: step 13, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 13, image 2 of 2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Top Panel Replacement: step 14, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 14, image 2 of 2
    • Pry open the side grip using a spudger.
  15. Canon EOS 300 Top Panel Replacement, Eyecup: step 15, image 1 of 2 Canon EOS 300 Top Panel Replacement, Eyecup: step 15, image 2 of 2
    • With your hands, remove the rubber grip from the eye piece.
  16. Canon EOS 300 Top Panel Replacement: step 16, image 1 of 1
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  17. Canon EOS 300 Top Panel Replacement, Top Panel: step 17, image 1 of 2 Canon EOS 300 Top Panel Replacement, Top Panel: step 17, image 2 of 2
    • Remove two silver 5.0mm Phillips #1 screws.
  18. Canon EOS 300 Top Panel Replacement: step 18, image 1 of 1
    • Remove the silver 5.5mm Phillips #1 screw.
  19. Canon EOS 300 Top Panel Replacement: step 19, image 1 of 2 Canon EOS 300 Top Panel Replacement: step 19, image 2 of 2
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
2 other people completed this guide.
Tammy Kong
771 Reputation
6 Guides authored
Cal Poly, Team 6-20, Maness Winter 2014 Member of Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Members
32 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 818
