Canon EOS 40D Shutter Button Replacement
  1. Canon EOS 40D Shutter Button Replacement, Battery: step 1, image 1 of 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Shutter Button Replacement: step 2, image 1 of 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Shutter Button Replacement: step 3, image 1 of 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Shutter Button Replacement, Shutter Button: step 4, image 1 of 1
    • Peel off the grip material from the body of the camera, exposing the screws.
  5. Canon EOS 40D Shutter Button Replacement: step 5, image 1 of 1
    • Remove the rubber eyepiece by sliding it upwards.
  6. Canon EOS 40D Shutter Button Replacement: step 6, image 1 of 2 Canon EOS 40D Shutter Button Replacement: step 6, image 2 of 2
    • Remove the three 5.0 mm Phillips #000 screws.
    • Remove the single 12.0 mm Phillips #000 screw.
  7. Canon EOS 40D Shutter Button Replacement: step 7, image 1 of 1
    • Remove the two 3.0 mm Phillips #000 screws on the bottom of the camera.
  8. Canon EOS 40D Shutter Button Replacement: step 8, image 1 of 2 Canon EOS 40D Shutter Button Replacement: step 8, image 2 of 2
    • Remove the side cover using a plastic opening tool or your hands.
    • Use a plastic opening tool to gently start prying the rear case up from the rest of the camera.
  9. Canon EOS 40D Shutter Button Replacement: step 9, image 1 of 2 Canon EOS 40D Shutter Button Replacement: step 9, image 2 of 2
    • Use the tip of a spudger to disconnect the ZIF connector on the left side of the camera.
    • The ribbon cable on this device was torn in the process of removing the back case, so there are no photos showing this step.
    • Disconnect the ribbon cable securing the rear case to the motherboard.
    • Separate the rear case from the camera.
  10. Canon EOS 40D Shutter Button Replacement: step 10, image 1 of 3 Canon EOS 40D Shutter Button Replacement: step 10, image 2 of 3 Canon EOS 40D Shutter Button Replacement: step 10, image 3 of 3
    • Remove the five 3.0 mm Phillips #000 screws.
    • Remove the two 5.0 mm Phillips #000 screws.
    • Remove the single 3.0 mm Phillips #000 screw.
  11. Canon EOS 40D Shutter Button Replacement: step 11, image 1 of 1
    • Pull off the cover.
  12. Canon EOS 40D Shutter Button Replacement: step 12, image 1 of 1
    • Use a plastic opening tool to flip up the black retaining flap on the ZIF connector.
    • Pull the ribbon cables free of the connectors.
  13. Canon EOS 40D Shutter Button Replacement: step 13, image 1 of 2 Canon EOS 40D Shutter Button Replacement: step 13, image 2 of 2
    • Remove the side panel by unscrewing three 5 mm JIS #000 screws.
  14. Canon EOS 40D Shutter Button Replacement: step 14, image 1 of 2 Canon EOS 40D Shutter Button Replacement: step 14, image 2 of 2
    • Remove the two 5 mm screws from under the wheel and under the shutter button using a JIS #000 screwdriver.
  15. Canon EOS 40D Shutter Button Replacement: step 15, image 1 of 3 Canon EOS 40D Shutter Button Replacement: step 15, image 2 of 3 Canon EOS 40D Shutter Button Replacement: step 15, image 3 of 3
    • Remove the red and yellow plugs from their sockets using the plastic opening tool.
    • Position the tip of the tool under the raised plastic line, then push up.
  16. Canon EOS 40D Shutter Button Replacement: step 16, image 1 of 3 Canon EOS 40D Shutter Button Replacement: step 16, image 2 of 3 Canon EOS 40D Shutter Button Replacement: step 16, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the cable running from the top of the camera to the black and white box.
    • Use a pair of precision tweezers to poke through the rubber coating and create a path for the wire to slide out.
    • Disconnect the wire by sliding it away from the rubber.
  17. Canon EOS 40D Shutter Button Replacement: step 17, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the two 5.0 mm screws and single 7.0 mm screw.
    • Notice that one is screwed in from the side.
  18. Canon EOS 40D Shutter Button Replacement: step 18, image 1 of 3 Canon EOS 40D Shutter Button Replacement: step 18, image 2 of 3 Canon EOS 40D Shutter Button Replacement: step 18, image 3 of 3
    • Once the screws are removed, wiggle the piece out of its socket and flip it over, exposing the shutter button.
    • Use tweezers to separate the piece from the ribbon that it is glued to.
3 other people completed this guide.
Kenadie Buccellato
444 Reputation
1 Guide authored
USF Tampa, Team 12-3, Blackwell Fall 2015 Member of USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Members
16 Guides authored
3 Guide Comments
Thanks for these instructions. I've successfully replaced the shutter button assembly on my Canon 50d using this guide.
William Eggers - Reply
Thank you for the tutorial. I don’t know how to replace the button. Which glue to use ? Must it scratch the connections on the flex circuit before gluing the new button ?
Tony - Reply
Thanks for this, but this is missing a lot of steps, and you didn't mention the jis #000 in the tools...
New Town - Reply
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 78
All Time: 10,501
