Canon EOS 60D Rear LCD Screen Removal
  1. Canon EOS 60D Rear LCD Screen Removal, Rear LCD Screen Dissasembly: step 1, image 1 of 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Removal: step 2, image 1 of 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Removal: step 3, image 1 of 2 Canon EOS 60D Rear LCD Screen Removal: step 3, image 2 of 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Removal: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
2 other people completed this guide.
Tyler Vaal
695 Reputation
3 Guides authored
USF Tampa, Team 16-6, Wollert Fall 2015 Member of USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,339
