PowerBook Duo 230 Disassembly
  1. PowerBook Duo 230 Disassembly, Preparation: step 1, image 1 of 1
    • Place the PowerBook Duo 230 on a clean table and prepare a Torx T8 screwdriver.
  2. PowerBook Duo 230 Disassembly, Battery: step 2, image 1 of 3 PowerBook Duo 230 Disassembly, Battery: step 2, image 2 of 3 PowerBook Duo 230 Disassembly, Battery: step 2, image 3 of 3
    • Push in the button as far as it will go.
    • Press and hold the button then simultaneously slide the battery cover to the left.
    • For greater security, you can now remove the battery.
  3. PowerBook Duo 230 Disassembly, Torx Screws: step 3, image 1 of 1
    • Loosen the 2 Torx screws.
    • The screws are the same.
  4. PowerBook Duo 230 Disassembly, Keyboard Removal: step 4, image 1 of 3 PowerBook Duo 230 Disassembly, Keyboard Removal: step 4, image 2 of 3 PowerBook Duo 230 Disassembly, Keyboard Removal: step 4, image 3 of 3
    • Turn your PowerBook over and open it.
    • Now you have to lift up the keyboard. Lift the keyboard by the upper part.
  5. PowerBook Duo 230 Disassembly, Keyboard Connector: step 5, image 1 of 3 PowerBook Duo 230 Disassembly, Keyboard Connector: step 5, image 2 of 3 PowerBook Duo 230 Disassembly, Keyboard Connector: step 5, image 3 of 3
    • Disconnect the keyboard from the Logicboard.
    • Now you need to move the small levers in every corner up. Be careful, small parts can break easily!
    • Gently pull out the flex cable.
Follow the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Nils
340 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 2,630
