Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement
  1. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: step 1, image 1 of 3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: step 1, image 2 of 3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: step 1, image 3 of 3
    • Hold the camera in a top view position allowing for a clear display of the broken top cover.
    • Observe and identify all the pieces of the shattered cover.
  2. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: step 2, image 1 of 3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: step 2, image 2 of 3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Slowly slide the tip of the tweezers under a piece of the broken cover and lift up to remove the broken piece.
    • Use the tweezers to remove another piece of the broken cover.
    • Repeat until all the pieces of the shattered cover are removed.
    • If you begin by removing a piece that is located at an edge of the broken cover, it would facilitate the removal of the rest of the pieces.
    • Use the tweezers carefully while removing the plastic pieces in order to avoid damaging the LCD screen beneath.
7 other people completed this guide.
Nazmi Bargouthi
591 Reputation
2 Guides authored
USF Tampa, Team 16-6, Wollert Fall 2015 Member of USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 29
All Time: 3,395
