Canon EOS Rebel G Back Panel Latch Replacement
  1. Canon EOS Rebel G Back Panel Latch Replacement, Front Panel: step 1, image 1 of 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Back Panel Latch Replacement: step 2, image 1 of 2 Canon EOS Rebel G Back Panel Latch Replacement: step 2, image 2 of 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Back Panel Latch Replacement: step 3, image 1 of 3 Canon EOS Rebel G Back Panel Latch Replacement: step 3, image 2 of 3 Canon EOS Rebel G Back Panel Latch Replacement: step 3, image 3 of 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Back Panel Latch Replacement, Back Panel Latch: step 4, image 1 of 1
    • Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
    • Two 4.3 mm Phillips screws
  5. Canon EOS Rebel G Back Panel Latch Replacement: step 5, image 1 of 1
    • Open the back panel by pushing the locking latch up.
    • Lift the latch cover off of the camera body.
  6. Canon EOS Rebel G Back Panel Latch Replacement: step 6, image 1 of 1
    • Slide the side latch (for the back door) up and then lift straight away from the camera body.
    • Sometimes the latch will detach while pushing it up.
Zach
43 Reputation
8 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
36 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 30
All Time: 2,605
