Canon EOS Rebel G Flash Replacement
  1. Canon EOS Rebel G Flash Replacement, Front Panel: step 1, image 1 of 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Flash Replacement: step 2, image 1 of 2 Canon EOS Rebel G Flash Replacement: step 2, image 2 of 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Flash Replacement: step 3, image 1 of 3 Canon EOS Rebel G Flash Replacement: step 3, image 2 of 3 Canon EOS Rebel G Flash Replacement: step 3, image 3 of 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Flash Replacement, Flash: step 4, image 1 of 2 Canon EOS Rebel G Flash Replacement, Flash: step 4, image 2 of 2
    • Pop the flash up with your thumb
  5. Canon EOS Rebel G Flash Replacement: step 5, image 1 of 1
    • Unscrew the two screws on the front of the flash near the bulb cover.
  6. Canon EOS Rebel G Flash Replacement: step 6, image 1 of 3 Canon EOS Rebel G Flash Replacement: step 6, image 2 of 3 Canon EOS Rebel G Flash Replacement: step 6, image 3 of 3
    • Close the flash.
    • Lift the flash cover off.
  7. Canon EOS Rebel G Flash Replacement: step 7, image 1 of 2 Canon EOS Rebel G Flash Replacement: step 7, image 2 of 2
    • Pull off yellow capacitor from flash wiring.
  8. Canon EOS Rebel G Flash Replacement: step 8, image 1 of 1
    • Remove white cocking with a razor blade, and then unsolder connection.
  9. Canon EOS Rebel G Flash Replacement: step 9, image 1 of 2 Canon EOS Rebel G Flash Replacement: step 9, image 2 of 2
    • Remove the flash cover to access the flash bulb.
    • After wires are unsoldered, slide flash bulb out from housing.
Zach
43 Reputation
8 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
36 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 2,490
