Canon EOS Rebel G Front Panel Replacement
  1. Canon EOS Rebel G Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Front Panel Replacement: step 2, image 1 of 2 Canon EOS Rebel G Front Panel Replacement: step 2, image 2 of 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Front Panel Replacement: step 3, image 1 of 3 Canon EOS Rebel G Front Panel Replacement: step 3, image 2 of 3 Canon EOS Rebel G Front Panel Replacement: step 3, image 3 of 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
Kyle Reis
52 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 24
All Time: 1,021
