Canon EOS Rebel G Grip Replacement
  1. Canon EOS Rebel G Grip Replacement, Front Panel: step 1, image 1 of 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Grip Replacement: step 2, image 1 of 2 Canon EOS Rebel G Grip Replacement: step 2, image 2 of 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Grip Replacement: step 3, image 1 of 3 Canon EOS Rebel G Grip Replacement: step 3, image 2 of 3 Canon EOS Rebel G Grip Replacement: step 3, image 3 of 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Grip Replacement, Grip: step 4, image 1 of 1
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Canon EOS Rebel G Grip Replacement: step 5, image 1 of 1
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Canon EOS Rebel G Grip Replacement: step 6, image 1 of 2 Canon EOS Rebel G Grip Replacement: step 6, image 2 of 2
    • Use the flat end of a spudger to pop the grip off and remove grip.
Kyle Reis
52 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
36 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,589
