Canon EOS Rebel G LCD Screen Replacement
  1. Canon EOS Rebel G LCD Screen Replacement, Front Panel: step 1, image 1 of 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G LCD Screen Replacement: step 2, image 1 of 2 Canon EOS Rebel G LCD Screen Replacement: step 2, image 2 of 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G LCD Screen Replacement: step 3, image 1 of 3 Canon EOS Rebel G LCD Screen Replacement: step 3, image 2 of 3 Canon EOS Rebel G LCD Screen Replacement: step 3, image 3 of 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G LCD Screen Replacement, Top Panel: step 4, image 1 of 1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G LCD Screen Replacement: step 5, image 1 of 1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G LCD Screen Replacement: step 6, image 1 of 1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G LCD Screen Replacement: step 7, image 1 of 3 Canon EOS Rebel G LCD Screen Replacement: step 7, image 2 of 3 Canon EOS Rebel G LCD Screen Replacement: step 7, image 3 of 3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G LCD Screen Replacement, LCD Screen: step 8, image 1 of 2 Canon EOS Rebel G LCD Screen Replacement, LCD Screen: step 8, image 2 of 2
    • Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
  9. Canon EOS Rebel G LCD Screen Replacement: step 9, image 1 of 1
    • Lift out the LCD screen.
Zach
43 Reputation
8 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
36 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,475
