Canon EOS Rebel G Lens Connector Replacement
  1. Canon EOS Rebel G Lens Connector Replacement, Front Panel: step 1, image 1 of 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Lens Connector Replacement: step 2, image 1 of 2 Canon EOS Rebel G Lens Connector Replacement: step 2, image 2 of 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Lens Connector Replacement: step 3, image 1 of 3 Canon EOS Rebel G Lens Connector Replacement: step 3, image 2 of 3 Canon EOS Rebel G Lens Connector Replacement: step 3, image 3 of 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Lens Connector Replacement, Lens Connector: step 4, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the 5 indicated screws
    • Five 6.2 mm Phillips screws
  5. Canon EOS Rebel G Lens Connector Replacement: step 5, image 1 of 1
    • Using your hands, remove the top black ring.
    • WARNING! The indicated piece is spring loaded. Prepare for it to eject when taking off top ring.
    • Spring located here.
  6. Canon EOS Rebel G Lens Connector Replacement: step 6, image 1 of 2 Canon EOS Rebel G Lens Connector Replacement: step 6, image 2 of 2
    • There are two silver metal rings.
    • Remove the top silver metal ring.
  7. Canon EOS Rebel G Lens Connector Replacement: step 7, image 1 of 1
    • Remove the bottom silver ring.
2 other people completed this guide.
Zach
43 Reputation
8 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
36 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,801
