Canon EOS Rebel T1i Camera Battery Notch Replacement
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: step 1, image 1 of 2 Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: step 1, image 2 of 2
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a #00 Phillips screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: step 2, image 1 of 2 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 2, image 2 of 2
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: step 3, image 1 of 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 3, image 2 of 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 3, image 3 of 3
    • Unscrew the bottom three 4mm screws with a #00 Phillips screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: step 4, image 1 of 1
    • Unscrew the inner 4mm screw with a #00 Phillips screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: step 5, image 1 of 2 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 5, image 2 of 2
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: step 6, image 1 of 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 6, image 2 of 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 6, image 3 of 3
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: step 7, image 1 of 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 7, image 2 of 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: step 7, image 3 of 3
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
4 other people completed this guide.
Jonathan Lin
548 Reputation
4 Guides authored
Cal Poly, Team 3-41, Maness Spring 2014 Member of Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 3,185
