Canon EOS Rebel T4i LCD Screen Replacement
  1. Canon EOS Rebel T4i LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i LCD Screen Replacement: step 2, image 1 of 1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i LCD Screen Replacement, LCD Screen: step 3, image 1 of 3 Canon EOS Rebel T4i LCD Screen Replacement, LCD Screen: step 3, image 2 of 3 Canon EOS Rebel T4i LCD Screen Replacement, LCD Screen: step 3, image 3 of 3
    • Remove the six screws on the housing of the LCD.
    • Four 3.1mm JIS screws on the side with the hinge.
    • Two 2.7mm JIS screws
  4. Canon EOS Rebel T4i LCD Screen Replacement: step 4, image 1 of 1
    • Remove the plastic back of the LCD.
  5. Canon EOS Rebel T4i LCD Screen Replacement: step 5, image 1 of 2 Canon EOS Rebel T4i LCD Screen Replacement: step 5, image 2 of 2
    • Unplug the blue cable attached to the back of the LCD.
7 other people completed this guide.
Jordan Rabold
807 Reputation
3 Guides authored
Cal Poly, Team 12-33, Maness Spring 2014 Member of Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Members
14 Guides authored
2 Comments
where can I buy a replacement LCD screen for my EOS650D camera in Adelaide. Australia
rdmahony4 - Reply
If it helps any, the part number for the LCD screen is CG2-4025. You can also try just searching something like "Canon EOS 650D LCD screen" on eBay to find a replacement screen.
Zephosk -
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 48
All Time: 5,911
