Canon EOS Rebel T5 Battery Replacement
  1. Canon EOS Rebel T5 Battery Replacement, Battery: step 1, image 1 of 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Battery Replacement: step 2, image 1 of 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
5 other people completed this guide.
Austin Tucker
1,027 Reputation
4 Guides authored
USF Tampa, Team 16-4, Wollert Fall 2015 Member of USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Members
16 Guides authored
One Comment
amigos saludos cordiales.
tengo un problema con mi canon t5 vi que le rompio o desprendio un pin de la parte de donde labateria encaja dentro de la camara la idea es como conectarla o soldarla? o repararla ls agradesco su atencion.
Eresma Lopez - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 43
All Time: 3,004
