Canon EOS Rebel T5 Image Sensor Replacement
  1. Canon EOS Rebel T5 Image Sensor Replacement, Battery: step 1, image 1 of 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Image Sensor Replacement: step 2, image 1 of 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Image Sensor Replacement, Back Cover: step 3, image 1 of 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Image Sensor Replacement: step 4, image 1 of 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Image Sensor Replacement: step 5, image 1 of 1
    • Turn your camera so that the bottom is facing you.
    • Remove the four 5mm JIS #000 screws.
  6. Canon EOS Rebel T5 Image Sensor Replacement: step 6, image 1 of 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
  7. Canon EOS Rebel T5 Image Sensor Replacement: step 7, image 1 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 7, image 2 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 7, image 3 of 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  8. Canon EOS Rebel T5 Image Sensor Replacement, Motherboard: step 8, image 1 of 2 Canon EOS Rebel T5 Image Sensor Replacement, Motherboard: step 8, image 2 of 2
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
    • Take note of this black cable and where it connects to the motherboard. This is a fiber optic cable which is used for the camera flash. It will need to be reconnected after replacing the motherboard.
    • When reconnecting the fiber optic cable, simply push the black cable into the hole in the connector and push it all the way in.
  9. Canon EOS Rebel T5 Image Sensor Replacement: step 9, image 1 of 1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm JIS #000 screws.
  10. Canon EOS Rebel T5 Image Sensor Replacement: step 10, image 1 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 10, image 2 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 10, image 3 of 3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  11. Canon EOS Rebel T5 Image Sensor Replacement: step 11, image 1 of 1
    • Remove the black 5 mm JIS #000 screw, located under the grip.
    • Remove the three 3.5mm JIS #000 screws on the bottom of the case.
  12. Canon EOS Rebel T5 Image Sensor Replacement: step 12, image 1 of 1
    • Remove the top panel of the device.
  13. Canon EOS Rebel T5 Image Sensor Replacement: step 13, image 1 of 2 Canon EOS Rebel T5 Image Sensor Replacement: step 13, image 2 of 2
    • Remove the front panel of the camera.
  14. Canon EOS Rebel T5 Image Sensor Replacement: step 14, image 1 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 14, image 2 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 14, image 3 of 3
    • Remove the five silver 5mm JIS #000 screws.
    • The motherboard can now be removed.
  15. Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: step 15, image 1 of 2 Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: step 15, image 2 of 2
    • The screws holding the image sensor in place is set to a very specific height. Unless they are returned to the exact same height after replacement, the camera will no longer be in focus unless the focus is recalibrated.
    • Remove the three silver 3mm JIS #000 screws from the image sensor holder.
    • Remove the image sensor holder.
  16. Canon EOS Rebel T5 Image Sensor Replacement: step 16, image 1 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 16, image 2 of 3 Canon EOS Rebel T5 Image Sensor Replacement: step 16, image 3 of 3
    • Remove the three remaining silver 3mm JIS #000 screws from the image sensor.
    • Be careful not lose the springs underneath the screws on the image sensor
    • Using your fingers, lift the image sensor from the device.
13 other people completed this guide.
Tyler Brown
906 Reputation
2 Guides authored
USF Tampa, Team 16-4, Wollert Fall 2015 Member of USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Members
18 Guides authored
3 Guide Comments
Thanks for the post. I was able to take this apart without damage to any of the camera parts. I am wondering if you happen to have the data sheet for the camera sensor, 704f? I cannot seem to find one.
Dawn - Reply
Hi. I do not see where it explains the calibration of the Sensor. Could you give me some reference about that?
ivanram - Reply
I reassembled on the camera no longer powers on, i checked disassembled again, checked for loose wires, ribbons, everything looks perfect and still it’s completely dead.
Edward Perkins - Reply
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 79
All Time: 8,862
