Canon EOS Rebel T5 Motherboard Replacement
  1. Canon EOS Rebel T5 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Motherboard Replacement: step 2, image 1 of 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Motherboard Replacement, Back Panel: step 3, image 1 of 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Motherboard Replacement: step 4, image 1 of 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Motherboard Replacement: step 5, image 1 of 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Canon EOS Rebel T5 Motherboard Replacement: step 6, image 1 of 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Canon EOS Rebel T5 Motherboard Replacement: step 7, image 1 of 3 Canon EOS Rebel T5 Motherboard Replacement: step 7, image 2 of 3 Canon EOS Rebel T5 Motherboard Replacement: step 7, image 3 of 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  8. Canon EOS Rebel T5 Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
  9. Canon EOS Rebel T5 Motherboard Replacement: step 9, image 1 of 1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm Phillips #000 screws.
  10. Canon EOS Rebel T5 Motherboard Replacement: step 10, image 1 of 3 Canon EOS Rebel T5 Motherboard Replacement: step 10, image 2 of 3 Canon EOS Rebel T5 Motherboard Replacement: step 10, image 3 of 3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  11. Canon EOS Rebel T5 Motherboard Replacement: step 11, image 1 of 1
    • Remove the black 5 mm Phillips #000 screw, located under the grip.
  12. Canon EOS Rebel T5 Motherboard Replacement: step 12, image 1 of 1
    • Remove the top panel of the device.
  13. Canon EOS Rebel T5 Motherboard Replacement: step 13, image 1 of 2 Canon EOS Rebel T5 Motherboard Replacement: step 13, image 2 of 2
    • Remove the front panel of the camera.
  14. Canon EOS Rebel T5 Motherboard Replacement: step 14, image 1 of 3 Canon EOS Rebel T5 Motherboard Replacement: step 14, image 2 of 3 Canon EOS Rebel T5 Motherboard Replacement: step 14, image 3 of 3
    • Remove the five silver 5mm Phillips #000 screws.
    • The motherboard can now be removed.
9 other people completed this guide.
Austin Tucker
1,027 Reputation
4 Guides authored
USF Tampa, Team 16-4, Wollert Fall 2015 Member of USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Members
16 Guides authored
2 Comments
This guide is amazing, but if you change the mainboard do you have to initialize it by software, like Spt?
Edgar Nunes - Reply
New main board from canon .
How to instalize?
Thomas Nguyen - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 35
All Time: 4,219
