Introduction
If the flash of your Canon Rebel T6i (also known as model EOS 750D) is malfunctioning — not producing any light or not triggering when taking a picture — use this guide to remove and replace the entire flash assembly.
Make sure to check the flash settings on your camera and confirm that the flash assembly is faulty. The camera flash should trigger when the camera mode is set to Automatic (A+) and the scene you are photographing is very dark.
Before beginning, remove the battery from your camera and disconnect from from any external power source.
Remove two 6.8 mm JIS #000 screws on the right side.
Remove six 5.3 mm JIS #000 screws on the bottom.
Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
Tool used on this step:Tweezers$4.99
Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
Remove the yellow and red connections on the front near the black cylinder (capacitor).
The yellow connector will just pop out if pried from the bottom using a plastic opening tool.
The red connector will pull out of the casing with either a plastic opening tool or a thin set of tweezers.
3 other people completed this guide.
