Canon EOS Rebel XSi Back Panel Replacement
  1. Canon EOS Rebel XSi Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Back Panel Replacement: step 2, image 1 of 1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Back Panel Replacement: step 3, image 1 of 1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Back Panel Replacement: step 4, image 1 of 1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Back Panel Replacement: step 5, image 1 of 1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Back Panel Replacement: step 6, image 1 of 1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Back Panel Replacement: step 7, image 1 of 1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Back Panel Replacement: step 8, image 1 of 1
    • Use hands to pry off the back panel.
3 other people completed this guide.
Erik Mork
602 Reputation
5 Guides authored
Cal Poly, Team 22-10, Maness Winter 2017 Member of Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,209
