Canon EOS Rebel XSi LCD Screen Replacement
  1. Canon EOS Rebel XSi LCD Screen Replacement, Back Panel: step 1, image 1 of 1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi LCD Screen Replacement: step 2, image 1 of 1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi LCD Screen Replacement: step 3, image 1 of 1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi LCD Screen Replacement: step 4, image 1 of 1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi LCD Screen Replacement: step 5, image 1 of 1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi LCD Screen Replacement: step 6, image 1 of 1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi LCD Screen Replacement: step 7, image 1 of 1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi LCD Screen Replacement: step 8, image 1 of 1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi LCD Screen Replacement, LCD Screen: step 9, image 1 of 1
    • Using the PH00 screwdriver head, unscrew four 4 mm screws and one 2 mm screw
  10. Canon EOS Rebel XSi LCD Screen Replacement: step 10, image 1 of 2 Canon EOS Rebel XSi LCD Screen Replacement: step 10, image 2 of 2
    • Remove the metal plate covering inside of the LCD screen
  11. Canon EOS Rebel XSi LCD Screen Replacement: step 11, image 1 of 1
    • Carefully disconnect the circuitry sheets from the white plastic bases
  12. Canon EOS Rebel XSi LCD Screen Replacement: step 12, image 1 of 2 Canon EOS Rebel XSi LCD Screen Replacement: step 12, image 2 of 2
    • Using the plastic spudger, carefully pry out the LCD screen from the back panel
Erik Mork
602 Reputation
5 Guides authored
Cal Poly, Team 22-10, Maness Winter 2017 Member of Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,748
