Canon EOS Rebel XTi Memory Card Replacement
  1. Canon EOS Rebel XTi Memory Card Replacement, Memory Card: step 1, image 1 of 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  2. Canon EOS Rebel XTi Memory Card Replacement: step 2, image 1 of 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  3. Canon EOS Rebel XTi Memory Card Replacement: step 3, image 1 of 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
Nicholas Abate
656 Reputation
5 Guides authored
USF Tampa, Team 8-6, Eyestone Fall 2015 Member of USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Members
18 Guides authored
One Comment
My camara wont read memory card
mcbed215 - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 3,401
