Canon ImageCLASS MF4350d Remove Right Side Paneling
  1. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Front Paneling: step 1, image 1 of 1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Remove Right Side Paneling: step 2, image 1 of 2 Canon ImageCLASS MF4350d Remove Right Side Paneling: step 2, image 2 of 2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Remove Right Side Paneling: step 3, image 1 of 2 Canon ImageCLASS MF4350d Remove Right Side Paneling: step 3, image 2 of 2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: step 4, image 1 of 3 Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: step 4, image 2 of 3 Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: step 4, image 3 of 3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
3 other people completed this guide.
Helena Yanez
455 Reputation
4 Guides authored
Cal Poly, Team 13-1, Forte Fall 2013 Member of Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Members
16 Guides authored
One Comment
Tore paper when removing jamed paper. A small piece of paper must still be in machine.
Louis Pike McCasland - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 4,142
