Canon ImageCLASS MF4350d Speaker Replacement
  1. Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Front Paneling: step 1, image 1 of 1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Speaker Replacement: step 2, image 1 of 2 Canon ImageCLASS MF4350d Speaker Replacement: step 2, image 2 of 2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Speaker Replacement: step 3, image 1 of 2 Canon ImageCLASS MF4350d Speaker Replacement: step 3, image 2 of 2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: step 4, image 1 of 3 Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: step 4, image 2 of 3 Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: step 4, image 3 of 3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Speaker Replacement, Speaker: step 5, image 1 of 1
    • Lay printer on its left side for better access to the speaker.
    • Note: The scanner lid needs to be supported when moving the printer
  6. Canon ImageCLASS MF4350d Speaker Replacement: step 6, image 1 of 2 Canon ImageCLASS MF4350d Speaker Replacement: step 6, image 2 of 2
    • Locate the black 7mm screw holding the speaker in place.
    • Using a Phillips head screw driver, unscrew the 7mm screw.
  7. Canon ImageCLASS MF4350d Speaker Replacement: step 7, image 1 of 3 Canon ImageCLASS MF4350d Speaker Replacement: step 7, image 2 of 3 Canon ImageCLASS MF4350d Speaker Replacement: step 7, image 3 of 3
    • Locate the red and black wires connected to the speaker.
    • Undo the white clip holding the wires in place by pinching the tab on the top.
    • Remove the red and black wires from the wire bundle.
    • When replacing the old speaker, do not touch any part of the new speaker that is not metal other than the wires. Doing so could damage the speaker.
    • Lift out the speaker
Helena Yanez
455 Reputation
4 Guides authored
Cal Poly, Team 13-1, Forte Fall 2013 Member of Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,390
