Canon ImageCLASS MF4350d Transformer Replacement
  1. Canon ImageCLASS MF4350d Transformer Replacement, Front Paneling: step 1, image 1 of 1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Transformer Replacement: step 2, image 1 of 2 Canon ImageCLASS MF4350d Transformer Replacement: step 2, image 2 of 2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Transformer Replacement: step 3, image 1 of 2 Canon ImageCLASS MF4350d Transformer Replacement: step 3, image 2 of 2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: step 4, image 1 of 3 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: step 4, image 2 of 3 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: step 4, image 3 of 3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: step 5, image 1 of 2 Canon ImageCLASS MF4350d Transformer Replacement, Transformer: step 5, image 2 of 2
    • Locate the yellow wire connected to the metal box.
    • Carefully pull the yellow wire from the black connector.
    • Wires may detach completely from plug so tug very gently.
  6. Canon ImageCLASS MF4350d Transformer Replacement: step 6, image 1 of 2 Canon ImageCLASS MF4350d Transformer Replacement: step 6, image 2 of 2
    • Locate the spring.
    • Unhook the spring on the side of the metal box.
  7. Canon ImageCLASS MF4350d Transformer Replacement: step 7, image 1 of 1
    • Unscrew the 10mm screw attaching the metal plate to the printer.
  8. Canon ImageCLASS MF4350d Transformer Replacement: step 8, image 1 of 1
    • Lift the transformer out of the printer.
Helena Yanez
461 Reputation
4 Guides authored
Cal Poly, Team 13-1, Forte Fall 2013 Member of Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 3,174
