Canon PIXMA MP190 Scan Bed Removal
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Canon PIXMA MP190 Scan Bed Removal, Remove Scanning Bed Cover: step 1, image 1 of 2 Canon PIXMA MP190 Scan Bed Removal, Remove Scanning Bed Cover: step 1, image 2 of 2
    • Lift scanning bed cover with one hand, and pry the right hinge inward using a plastic opening tool.
    • The cover will lift up and away from the printer.
  2. Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: step 2, image 1 of 2 Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: step 2, image 2 of 2
    • Lift the scan bed into the upright position.
    • Ensure the scanning unit support seats into the scanning unit support slot.
    • The four arrow markers located on the bottom edge of the scan bed mark the four tabs that must be released.
  3. Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: step 3, image 1 of 2 Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: step 3, image 2 of 2
    • Place a plastic opening tool at each of the four marking arrows.
    • The scan bed will detach from the scan bed unit. Lift scan bed glass upward to access the bottom surface of the glass.
  4. Canon PIXMA MP190 Scan Bed Removal, Cleaning the Scan Bed Glass: step 4, image 1 of 1
    • Using the screen and device cleaner and cloth remove any dirt or debris from the bottom surface of the scan glass.
  5. Canon PIXMA MP190 Scan Bed Removal, Reassemble Scan Bed Unit: step 5, image 1 of 2 Canon PIXMA MP190 Scan Bed Removal, Reassemble Scan Bed Unit: step 5, image 2 of 2
    • Lower the scan bed glass down on to the scanning unit until the clips reengage.
    • Clean the top surface of the scan bed glass using the screen and device cleaner and cloth.
    • Put the scan bed cover back on by placing the left hinge in first.
    • Then snap the right hinge into place.
    • The printer is now ready to scan or copy.
2 other people completed this guide.
Garret Wescott
597 Reputation
4 Guides authored
Michigan Tech, Team 1-5, Lauer Fall 2014 Member of Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 438
