Canon PIXMA MP620B Command Screen Replacement
  1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: step 1, image 1 of 1
    • Open top lid of the printer to reveal the scanner
  2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: step 2, image 1 of 2 Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: step 2, image 2 of 2
    • Insert the spudger tool into the top lid in between the blue and the black panels.
    • Use this tool to pry the two panels apart
  3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: step 3, image 1 of 1
    • After these two panels are separated, set the top panel to the side for now
  4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: step 4, image 1 of 1
    • Unplug the two wires shown at the right of the command screen
  5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: step 5, image 1 of 1
    • Unscrew the four screws shown to detach the command screen from the printer
  6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: step 6, image 1 of 1
    • Take the detached command screen off of the printer and replace.
4 other people completed this guide.
Val Fedorikhin
860 Reputation
5 Guides authored
Cal Poly, Team 6-21, Maness Fall 2014 Member of Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Members
10 Guides authored
2 Comments
Ideas as to where to buy replacement screen assembly?
davepi49 - Reply
same question
Jan de Ruiter -
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,361
