Canon Pixma MP480 Data Port Replacement
  1. Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: step 1, image 1 of 2 Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: step 1, image 2 of 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Canon Pixma MP480 Data Port Replacement: step 2, image 1 of 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Canon Pixma MP480 Data Port Replacement: step 3, image 1 of 1
    • Open the front tray.
  4. Canon Pixma MP480 Data Port Replacement: step 4, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 4, image 2 of 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Canon Pixma MP480 Data Port Replacement: step 5, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 5, image 2 of 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Canon Pixma MP480 Data Port Replacement: step 6, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 6, image 2 of 2
    • Pry open the side cover with the plastic opening tool.
  7. Canon Pixma MP480 Data Port Replacement: step 7, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 7, image 2 of 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Canon Pixma MP480 Data Port Replacement: step 8, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 8, image 2 of 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
  9. Canon Pixma MP480 Data Port Replacement, LCD: step 9, image 1 of 2 Canon Pixma MP480 Data Port Replacement, LCD: step 9, image 2 of 2
    • Using the plastic opening tool, pry off the top cover of the LCD assembly.
    • Pry around the front and side edges for the easiest removal.
  10. Canon Pixma MP480 Data Port Replacement: step 10, image 1 of 1
    • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
  11. Canon Pixma MP480 Data Port Replacement: step 11, image 1 of 1
    • Gently pull the ribbon cable to remove the LCD completely.
  12. Canon Pixma MP480 Data Port Replacement, Buttons: step 12, image 1 of 1
    • Locate the buttons on the top of the printer.
  13. Canon Pixma MP480 Data Port Replacement: step 13, image 1 of 1
    • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
  14. Canon Pixma MP480 Data Port Replacement: step 14, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 14, image 2 of 2
    • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
  15. Canon Pixma MP480 Data Port Replacement: step 15, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 15, image 2 of 2
    • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
  16. Canon Pixma MP480 Data Port Replacement: step 16, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 16, image 2 of 2
    • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
  17. Canon Pixma MP480 Data Port Replacement: step 17, image 1 of 1
    • Gently pull the LCD screen up to remove it from its fixture.
  18. Canon Pixma MP480 Data Port Replacement: step 18, image 1 of 1
    • Use the plastic opening tool to pry off the plastic button assembly.
  19. Canon Pixma MP480 Data Port Replacement: step 19, image 1 of 1
    • Gently pull the plastic button assembly up to remove it.
    • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
  20. Canon Pixma MP480 Data Port Replacement: step 20, image 1 of 1
    • Remove the ribbon cable connected to the backside of the plastic button assembly.
  21. Canon Pixma MP480 Data Port Replacement: step 21, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 21, image 2 of 2
    • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
  22. Canon Pixma MP480 Data Port Replacement: step 22, image 1 of 3 Canon Pixma MP480 Data Port Replacement: step 22, image 2 of 3 Canon Pixma MP480 Data Port Replacement: step 22, image 3 of 3
    • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
    • Gently lift the spring and pull the board out of its plastic button assembly.
  23. Canon Pixma MP480 Data Port Replacement: step 23, image 1 of 1
    • Remove the buttons from the plastic button assembly.
  24. Canon Pixma MP480 Data Port Replacement, Data Port: step 24, image 1 of 2 Canon Pixma MP480 Data Port Replacement, Data Port: step 24, image 2 of 2
    • Remove the 7.5 mm screw using the Phillips #1 screwdriver.
  25. Canon Pixma MP480 Data Port Replacement: step 25, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 25, image 2 of 2
    • Remove the five 3.5 mm screws using the Phillips #1 screwdriver.
  26. Canon Pixma MP480 Data Port Replacement: step 26, image 1 of 1
    • Remove the small plastic clip using the spudger.
  27. Canon Pixma MP480 Data Port Replacement: step 27, image 1 of 1
    • Pull the plastic inserts out of the holes in the top and bottom.
  28. Canon Pixma MP480 Data Port Replacement: step 28, image 1 of 1
    • Remove the board from the printer by pulling the board towards the back of the printer.
    • This requires effort and time as the board comes out slowly.
Steven MacLean
86 Reputation
2 Guides authored
Cal Poly, Team 19-41, Regan Winter 2013 Member of Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,213
