Canon PowerShot A3400 IS Plastic Case Replacement
  1. Canon PowerShot A3400 IS Plastic Case Replacement, Battery: step 1, image 1 of 1
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Plastic Case Replacement: step 2, image 1 of 1
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: step 3, image 1 of 2 Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: step 3, image 2 of 2
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Plastic Case Replacement: step 4, image 1 of 2 Canon PowerShot A3400 IS Plastic Case Replacement: step 4, image 2 of 2
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Plastic Case Replacement: step 5, image 1 of 1
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Plastic Case Replacement: step 6, image 1 of 1
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Plastic Case Replacement: step 7, image 1 of 1
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Plastic Case Replacement: step 8, image 1 of 2 Canon PowerShot A3400 IS Plastic Case Replacement: step 8, image 2 of 2
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Plastic Case Replacement: step 9, image 1 of 3 Canon PowerShot A3400 IS Plastic Case Replacement: step 9, image 2 of 3 Canon PowerShot A3400 IS Plastic Case Replacement: step 9, image 3 of 3
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Plastic Case Replacement: step 10, image 1 of 3 Canon PowerShot A3400 IS Plastic Case Replacement: step 10, image 2 of 3 Canon PowerShot A3400 IS Plastic Case Replacement: step 10, image 3 of 3
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
Emily Pretorius
337 Reputation
3 Guides authored
USF Tampa, Team 1-1, Sullivan Winter 2015 Member of USF Tampa, Team 1-1, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G1
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 261
