Canon PowerShot A4000 IS Flash Replacement
Ansley Gardner
Ansley Gardner and 3 other contributors
Last updated on March 10, 2020
No estimate
Moderate
Better Introduction
Tools
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: step 1, image 1 of 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: step 1, image 2 of 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: step 1, image 3 of 3
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: step 2, image 1 of 2 Canon PowerShot A4000 IS Flash Replacement: step 2, image 2 of 2
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: step 3, image 1 of 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: step 3, image 2 of 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: step 3, image 3 of 3
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Ansley Gardner
761 Reputation
7 Guides authored
Clemson, Team 1-3, Benson Fall 2014 Member of Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Members
17 Guides authored
One Comment
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,816
