Canon PowerShot A460 Front Casing Replacement
  1. Canon PowerShot A460 Front Casing Replacement, Battery: step 1, image 1 of 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Front Casing Replacement: step 2, image 1 of 1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Front Casing Replacement: step 3, image 1 of 1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Front Casing Replacement, Front Casing: step 4, image 1 of 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Front Casing Replacement: step 5, image 1 of 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Front Casing Replacement: step 6, image 1 of 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Front Casing Replacement: step 7, image 1 of 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Front Casing Replacement: step 8, image 1 of 2 Canon PowerShot A460 Front Casing Replacement: step 8, image 2 of 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Front Casing Replacement: step 9, image 1 of 3 Canon PowerShot A460 Front Casing Replacement: step 9, image 2 of 3 Canon PowerShot A460 Front Casing Replacement: step 9, image 3 of 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Front Casing Replacement: step 10, image 1 of 3 Canon PowerShot A460 Front Casing Replacement: step 10, image 2 of 3 Canon PowerShot A460 Front Casing Replacement: step 10, image 3 of 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
2 other people completed this guide.
Alex
112 Reputation
2 Guides authored
Cal Poly, Team 19-42, Regan Winter 2013 Member of Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 35
All Time: 1,172
