Canon PowerShot A540 SD Card Reader Replacement
Cooper Hale
Cooper Hale and 3 other contributors
Last updated on May 7, 2024
15 - 20 minutes
Moderate
Introduction
Go to step 1
If your camera keeps showing you an "SD card error"message, but the SD card in use is the correct type and is uncorrupted, your SD card reader may be in need of replacement. After removing the back cover and the LCD screen, you will be able to replace the SD card reader yourself.
Tools
  1. Canon PowerShot A540 SD Card Reader Replacement, Back Cover: step 1, image 1 of 2 Canon PowerShot A540 SD Card Reader Replacement, Back Cover: step 1, image 2 of 2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 SD Card Reader Replacement: step 2, image 1 of 1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 SD Card Reader Replacement: step 3, image 1 of 1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 SD Card Reader Replacement: step 4, image 1 of 1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 SD Card Reader Replacement: step 5, image 1 of 3 Canon PowerShot A540 SD Card Reader Replacement: step 5, image 2 of 3 Canon PowerShot A540 SD Card Reader Replacement: step 5, image 3 of 3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: step 6, image 1 of 2 Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: step 6, image 2 of 2
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 SD Card Reader Replacement: step 7, image 1 of 2 Canon PowerShot A540 SD Card Reader Replacement: step 7, image 2 of 2
    Tool used on this step:
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 SD Card Reader Replacement: step 8, image 1 of 3 Canon PowerShot A540 SD Card Reader Replacement: step 8, image 2 of 3 Canon PowerShot A540 SD Card Reader Replacement: step 8, image 3 of 3
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 SD Card Reader Replacement: step 9, image 1 of 2 Canon PowerShot A540 SD Card Reader Replacement: step 9, image 2 of 2
    • Remove the two (2) 3.0 mm screws shown with the Phillips head #000 screwdriver.
  10. Canon PowerShot A540 SD Card Reader Replacement: step 10, image 1 of 2 Canon PowerShot A540 SD Card Reader Replacement: step 10, image 2 of 2
    • Remove the ribbon from the clamp/bar securing it by using your tweezers to pull the bar up.
  11. Canon PowerShot A540 SD Card Reader Replacement: step 11, image 1 of 1
    • Remove the SD Card reader and replace.
    • There is another metal bar that comes off of the SD Card reader when screws are removed.
2 other people completed this guide.
Cooper Hale
598 Reputation
3 Guides authored
Baylor, Team 7-12, Williams Spring 2015 Member of Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Members
20 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,360
