Canon PowerShot A590 IS Memory Card Replacement
Zach
Zach and 5 other contributors
Last updated on March 19, 2020
5 minutes
Very easy
Missing Steps
Introduction
Go to step 1
This guide will instruct the user on how to open the bottom hatch to access the batteries and memory card, and to remove and replace the memory card.
  1. Canon PowerShot A590 IS Memory Card Replacement, Open the Battery Hatch: step 1, image 1 of 1
    • Be gentle with the hatch, it is fragile.
    • *See battery replacement guide for help opening the hatch.
  2. Canon PowerShot A590 IS Memory Card Replacement, Locate Memory Card: step 2, image 1 of 1
    • The memory card slot is shown here in the red rectangle.
  3. Canon PowerShot A590 IS Memory Card Replacement, Remove Memory Card: step 3, image 1 of 1
    • To eject your memory card, simply press it into the camera gently, and it will spring out.
    • After it has been released from the camera, just pull it out.
  4. Canon PowerShot A590 IS Memory Card Replacement, Replace Memory Card: step 4, image 1 of 1
    • To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
    • Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
4 other people completed this guide.
Zach
284 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 5,686
