Canon PowerShot A620 Camera Housing Replacement
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: step 1, image 1 of 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: step 1, image 2 of 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: step 1, image 3 of 3
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: step 2, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: step 2, image 2 of 2
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: step 3, image 1 of 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: step 3, image 2 of 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: step 3, image 3 of 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: step 4, image 1 of 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: step 5, image 1 of 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 6, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 6, image 2 of 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: step 7, image 1 of 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: step 8, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Front Panel: step 8, image 2 of 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 9, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 9, image 2 of 2
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: step 10, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: step 10, image 2 of 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: step 11, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Back Panel: step 11, image 2 of 2
    • Gently pull the back panel to separate it from the camera.
2 other people completed this guide.
Jaime Abraham
350 Reputation
3 Guides authored
CSU Fullerton, Team 1-1, Bruce Fall 2014 Member of CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Members
6 Guides authored
One Comment
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 1,565
