Canon PowerShot A630 LCD Screen Replacement
  1. Canon PowerShot A630 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Open the LCD screen of the camera
  2. Canon PowerShot A630 LCD Screen Replacement: step 2, image 1 of 2 Canon PowerShot A630 LCD Screen Replacement: step 2, image 2 of 2
    • Rotate the screen so that it is perpendicular to the body of the camera
    • Remove the .2mm screw using a Phillips #00 screwdriver
    • Rotate screen 180 degrees and remove second .2mm screw
  3. Canon PowerShot A630 LCD Screen Replacement: step 3, image 1 of 2 Canon PowerShot A630 LCD Screen Replacement: step 3, image 2 of 2
    • Gently remove the back panel of the LCD screen
  4. Canon PowerShot A630 LCD Screen Replacement: step 4, image 1 of 1
    • Once the back panel is removed another .2mm screw will be revealed, remove this screw to remove the front panel of the LCD screen
  5. Canon PowerShot A630 LCD Screen Replacement: step 5, image 1 of 1
    • Gently remove front panel of the LCD screen
  6. Canon PowerShot A630 LCD Screen Replacement: step 6, image 1 of 2 Canon PowerShot A630 LCD Screen Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Locate the ribbon (orange) and using tweezers gently pull back the retaining clip and pull the ribbon out
  7. Canon PowerShot A630 LCD Screen Replacement: step 7, image 1 of 3 Canon PowerShot A630 LCD Screen Replacement: step 7, image 2 of 3 Canon PowerShot A630 LCD Screen Replacement: step 7, image 3 of 3
    • Use a spudger to gently remove the LCD screen from the metal backing plate
2 other people completed this guide.
Kady Rose
201 Reputation
1 Guide authored
Clemson, Team 2-5, Benson Fall 2014 Member of Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Members
18 Guides authored
One Comment
Where can I purchase a replacement LCD screen?
steigw - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 45
All Time: 2,216
