Canon PowerShot A630 Shooting Mode Dial Replacement
  1. Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: step 1, image 1 of 2 Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: step 1, image 2 of 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Shooting Mode Dial Replacement: step 2, image 1 of 2 Canon PowerShot A630 Shooting Mode Dial Replacement: step 2, image 2 of 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Shooting Mode Dial Replacement: step 3, image 1 of 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Shooting Mode Dial Replacement: step 4, image 1 of 2 Canon PowerShot A630 Shooting Mode Dial Replacement: step 4, image 2 of 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Shooting Mode Dial Replacement: step 5, image 1 of 2 Canon PowerShot A630 Shooting Mode Dial Replacement: step 5, image 2 of 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Shooting Mode Dial Replacement: step 6, image 1 of 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Shooting Mode Dial Replacement: step 7, image 1 of 2 Canon PowerShot A630 Shooting Mode Dial Replacement: step 7, image 2 of 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: step 8, image 1 of 2 Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: step 8, image 2 of 2
    • Pry open the connector on the yellow ribbon cable using a plastic opening tool.
  9. Canon PowerShot A630 Shooting Mode Dial Replacement: step 9, image 1 of 1
    • Remove the 2 mm screws from the metal plate.
  10. Canon PowerShot A630 Shooting Mode Dial Replacement: step 10, image 1 of 1
    • Pull away the metal plate, exposing the underbelly of the mode dial.
    • Be careful not to pull too hard. Metal plate should remain attached.
  11. Canon PowerShot A630 Shooting Mode Dial Replacement: step 11, image 1 of 2 Canon PowerShot A630 Shooting Mode Dial Replacement: step 11, image 2 of 2
    • Remove the 2mm screw using the #00 Phillips screwdriver.
    • The mode dial should fall out.
Alicia Burns
600 Reputation
5 Guides authored
Clemson, Team 2-5, Benson Fall 2014 Member of Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 567
