Canon PowerShot A75 Casing Replacement
  1. Canon PowerShot A75 Casing Replacement, Batteries: step 1, image 1 of 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Casing Replacement: step 2, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 2, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 2, image 3 of 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Casing Replacement: step 3, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 3, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 3, image 3 of 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Casing Replacement, Casing: step 4, image 1 of 1
    • Remove the three 2.5mm screws on the bottom of the camera.
  5. Canon PowerShot A75 Casing Replacement: step 5, image 1 of 1
    • Remove the 3.8mm screw underneath the flap that covers the A/V port.
  6. Canon PowerShot A75 Casing Replacement: step 6, image 1 of 2 Canon PowerShot A75 Casing Replacement: step 6, image 2 of 2
    • Remove the 2.4mm screw located underneath the cover of the memory card slot.
  7. Canon PowerShot A75 Casing Replacement: step 7, image 1 of 2 Canon PowerShot A75 Casing Replacement: step 7, image 2 of 2
    • Open the memory card slot by sliding it laterally until you hear a click.
    • Remove the 5.9mm screw in the upper corner of the memory card slot.
  8. Canon PowerShot A75 Casing Replacement: step 8, image 1 of 1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  9. Canon PowerShot A75 Casing Replacement: step 9, image 1 of 2 Canon PowerShot A75 Casing Replacement: step 9, image 2 of 2
    • Lift the shutter button and speaker part from the top of the camera.
    • DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
  10. Canon PowerShot A75 Casing Replacement: step 10, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 10, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  11. Canon PowerShot A75 Casing Replacement: step 11, image 1 of 1
    • Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
  12. Canon PowerShot A75 Casing Replacement: step 12, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 12, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 12, image 3 of 3
    • Separate the back casing and front casing of the camera using your hands.
    • Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
  13. Canon PowerShot A75 Casing Replacement: step 13, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 13, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 13, image 3 of 3
    • On the front of the camera, press the button on the lower left of the lens.
    • Twist the outer lens casing counter-clockwise and slide it out.
  14. Canon PowerShot A75 Casing Replacement: step 14, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 14, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 14, image 3 of 3
    • Take off the front casing.
    • There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
4 other people completed this guide.
Andrew Elliott
13 Reputation
1 Guide authored
Cal Poly, Team 17-30, Amido Spring 2012 Member of Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Members
12 Guides authored
1 Guide Comment
Thank you for this detailed guide. It helped me to gain access to the electrical contacts in the battery compartment to remove alkaline battery corrosion
Jef B - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,760
