Canon PowerShot A75 Speaker Replacement
  1. Canon PowerShot A75 Speaker Replacement, Batteries: step 1, image 1 of 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Speaker Replacement: step 2, image 1 of 3 Canon PowerShot A75 Speaker Replacement: step 2, image 2 of 3 Canon PowerShot A75 Speaker Replacement: step 2, image 3 of 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Speaker Replacement: step 3, image 1 of 3 Canon PowerShot A75 Speaker Replacement: step 3, image 2 of 3 Canon PowerShot A75 Speaker Replacement: step 3, image 3 of 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Speaker Replacement, Speaker: step 4, image 1 of 2 Canon PowerShot A75 Speaker Replacement, Speaker: step 4, image 2 of 2
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  5. Canon PowerShot A75 Speaker Replacement: step 5, image 1 of 1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  6. Canon PowerShot A75 Speaker Replacement: step 6, image 1 of 2 Canon PowerShot A75 Speaker Replacement: step 6, image 2 of 2
    • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  7. Canon PowerShot A75 Speaker Replacement: step 7, image 1 of 3 Canon PowerShot A75 Speaker Replacement: step 7, image 2 of 3 Canon PowerShot A75 Speaker Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  8. Canon PowerShot A75 Speaker Replacement: step 8, image 1 of 1
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
Austin Fox
1 Reputation
2 Guides authored
Cal Poly, Team 17-30, Amido Spring 2012 Member of Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 423
