Canon PowerShot ELPH330 HS Camera Case Replacement
Michelle Ngo
Michelle Ngo and 3 other contributors
Last updated on September 18, 2019
2 - 5 minutes
Moderate
Action Shots
Missing Details
Introduction
Go to step 1
Is your camera case cracked or broken? Are there dust particles and dirt getting into your camera? You may want to consider replacing the case of your camera if the symptoms mentioned above are present.
Before starting your replacement for the canon case, make sure to be in a space that is dust-free and very open. During this replacement, there will be many small screws used.
Parts
Tools
Show more…
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: step 1, image 1 of 2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: step 1, image 2 of 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: step 2, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: step 3, image 1 of 1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: step 4, image 1 of 1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: step 5, image 1 of 1
    • Using your fingers, carefully pry the case apart at the seam.
Michelle Ngo
595 Reputation
3 Guides authored
UW Tacoma, Team S1-G3, Liner Summer 2019 Member of UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 216
